- May 20, 2010
Anyone any thoughts on the back axle being kicked over when the trucks lifted? When I had mine tracked this was mentioned as the truck is actually crabbing as it goes done the road
Great lakes pics, done a bit of mountain biking there but not familiar with the area really. Have you got a copy of the route you did? No problems with the camping or walkers waving there sticks at you?
I would like a copy of the route or it's location please if possible.
Mines just over an inch out Clive
I would use 2x 80 series front panard rods made adjustable just using the top secions of the two. Then you have a solid rear adjustable bar. As the rear is hollow as you know for sure. Then 1/2 load the truck and centre the rear axle. Should be 50 per cent out either fully loaded or empty. Should be a winner!
Sounds good to me
I've heard there's a guy on this forum sells s/h bits for 80's, now what's his name?... Ermmm...
Just give me the order and ill sort it some time this year ....... Shouldn't really joke about how shite I can be at times.
Yeah looks well iwan, good shed hidden away in the depths of wales too.Its that secret you only work under the cover of darkness....
Hi Iwan that looks a good job you have done but you got a big Job with the conversion have fun with it and lot's pics thanks from Tony .
Blind rivets and a good quality adhesive/sealant.So I got the auto gear out and got it all the manual bit's ready to install.
After sorting out the alarm wiring and rear fog light wiring that had been fitted through the bung that blocks off the clutch master cylinder area. I found the issue that the top mount for the clutch pedal assembly is missing.
This is it on the parts truck. It wasn't an issue to remove but fitting it to mine is an issue in more ways than one.
To weld it in is quite frankly a fire hazard! Unless I remove the conbustable items like the carpet and under carpet etc.
The other way is to bolt it in but it means to drill and then seal the holes in the area below the scuttle panel where the wiper mech is. Its a bit of a water way above there and dont fancy driving around with a wet left foot.
There's not much to it, But without it, it wouldn't be long before the pedal mech goes through the bulkhead. Really flexy and reliant on the upper mount.
Looks good with the missing part in there and with the extra pedal in there. But no good if its not reliable. Any thoughts? Bolt it in I am prefering..
