SafariTecPeter
- Apr 29, 2016
Hello All!
I need to get some help on this & shed some light on a dark situation.
I have a `98 Land Cruiser J9 with 230`000km on the clock. 1KZ-TE Engine & Autobox.
The following is vital; Car was driven by someone else & he said he had "driven it hard" (no tow) down what You guys would call a Motorway. Uncertain for how long, but the speed was aboce 150km/h... Don`t know what revs...
Upon pulling over, the engine developed a very bad metallic knock. I told him to discontinue the trip & we picked up the car on by trailer. No deviation in cooling water nor oil level.
The car had been fueled while being "out there".
Brought it home, the engine still knocks as if it was going out of fashion.
So here is what I have done so far;
Drained & filteres engine oil. New oil filer. Found no contamination in the above suggesting fi a shot con rod bearing
Fresh diesel with conditioner & fuel filter. Old fuel filter was full of "gooo"
All injectors are OK, the get fuel. No seriouse know comming from either injector.
Timing checked-> OK
Cam inspected-> No deviation visable
All Fluid levels are stabile, I do not recon the head is gone (leaking/cracked)
I have driven it with the knock, the power seems to be there even if I did not "give it hard"....
Fault codes checked & cleared ECU. Nothing
Measured all sensors on injection pump-> They are fine
Also tested the TCV, its definately working.
There is very little to suggest the flex plate is bust, but I can`t rule it out....
I can`t pinpoint where the metallic knock is comming from.
As I can`t pull the oilpan without lifting the engine, this has been put on hold for now.
I have been hesitant to pull the head "just for fun".... At least for know I still can move the car around (vital)
I would really really appreciate some good hints & clues on what else tolook for before I break out the engine hoist...
PRETTY PLEASE
Thanks Guys!
Timing checked-> OK
PRETTY PLEASE
Thanks Guys!
