- Feb 2, 2013
Although I don't know too much about these engines It sounds to me like the piston is kissing the head.
Which aptly describes the early detonation noise you get if you spray egr cleaner into the intake for more than 2 seconds . Both my engines have produced that noise a number of times , albeit only momentarily , and both run sweet as a nut . So unlikely as it may sound i have to assume the engine can make that noise without component failure .
Beau did a walk through youtube vid on how to remove the 1kz from a 90 which might prove useful .
