LJ70 Build Thread!
Thanks mate. :thumbup:
Plan is to join my old 4wd club once back in Melbourne, the Dandenong Ranges 4wd club. :dance:
Before I left there was talk of the club starting to do club reg, but looking at the huge list on the VicRoads website I cant see their name so maybe that never eventuated, I will have to ask them.
Failing that I may join the Landcruiser club of Victoria. I was put off that club years ago as they insist on you doing a days 4wd training before you can go on any of their trips, but when speaking to Club4x4 insurance recently for a quote the guy asked if I had done any certified courses for driver training and if I had it results in a nice discount, so that would be good if I go through that club for my club reg. :think:
All of my old bosses historic Toyota's are on club reg through that club too. :icon-biggrin:
Roadworthy isnt a problem, I know a guy. :shifty:
I was a member of 3rd Rock when I lived in Boronia. A good bunch but I don't think they are going any more.
Just checked out your rotisserie, it looks so much easier welding the shell up on there.
Looks like your cruisers are coming along nicely and your fully committed as ever.
  • Like
Reactions: Ben
Cool. :icon-cool:
Not heard of them, so I imagine they are no more. :thumbdown:
Thanks mate, its getting there. :thumbup:
The body has been so much easier on the rotisserie! :dance:
I couldnt have done what I'm doing, without it! :clap:
Update time! :dance:
I hooked the crane up to the bulkhead ready to begin the amputation! :auto-ambulance:
And began cutting.
I then carefully prised the sections apart.
Inside the sills there was a lot of dirt.
I moved the crane to the rear of the body and rigged it up for lifting.
I then lowered the body down onto the chassis and pushed it outside.
I gave the sills a good wash out with the hose.
Once it was dry I pushed it back into the garage.
I drilled the spot welds out and marked where I needed to cut the ends off the inner sills.
And other side.
The sills had at some point been filled with a waxy grease like substance and this seems to have helped preserve them quite well, seen as their one of the least rusty areas on the body.
It was then time to get the new bulkhead removed and prepped ready for fitting.
I set the gazebo up and got the 75 body under it ready for cutting.
And put the old bulkhead next to it so I could compare cut marks.
After marking where to cut and triple checking, I cut! :icon-twisted:
I purposely cut it oversize, so it would need a bit more work.
First job was to remove the sections of outer sill that came off with the bulkhead, as I would obviously be using my original outer sills.
So after drilling the spot welds out and carefully prising and levering I had one off.
The inner sill would be staying as it would need to be welded onto my original one, but would need trimming to length still.
Other side.
And they were both off!
I cut the end off the inner sill off cut off the original body, to use as a template to cut the new ones.
I then gave the floor pan its final mark and cut.
And that was the new rot free bulkhead all ready to go on! :icon-cool:
Moment of truth! :pray:
Fitted like a glove! :character-beavisbu:
Next I tried the doors on to make sure they would fit OK.
Drivers side was good.
But the passenger side wasnt perfect. :doh:
It was OK and would work but the gap was running out by about 5mm and I wasnt happy with it. :shifty:
I couldnt get enough adjustment out of the hinges and the distance between the A pillar and B pillars was the same as the drivers side, so I decided to die grind out the holes in the top hinge to give me a bit more adjustment.
After grinding that out the holes the door now had a perfect gap!
I then removed the doors and bulkhead and got the bulkhead onto the bench for a slight bit of trimming.
It didnt need much off and in hindsight I wish I had left both floor pan sections a bit over size as it was very easy to slide it under the rear section and mark the cut. :think:
I cleaned up the sills on both sections, grinding down any old spot welds and cleaning any grime out of the inner sills.
Then it was tie to give any sections that will be enclosed a good coat of weld through zinc paint to protect the metal against corrosion.
I refitted the bulkhead and bolted both the body and bulkhead down to the chassis.
I clamped the new inner sill sections to the outers with vice grips (mole grips if your in the UK).
As well as the edges of the transmission tunnel join.
The floor pan join on the drivers side wasnt perfect with a slight gap in one section of about 4mm. :doh:
But the other side was perfect.
I refitted the doors again just to double check it was all going to work OK before welding.
Again drivers side was perfect.
But passenger side still wasnt 100%.
So I fitted a wedge to help keep the gap nice while welding.
I then fitted lots of clamps and panel beat the sheet metal sections back together ready for welding.
All done!
The doors came back off.
I had mistakenly removed some spot welds from the top of the sill that hold the outer and inner together. :icon-redface:
So I clamped and welded those sections back together next.
Top tip of the week, holding a piece of copper behind a hole you need to fill in, really helps as the weld wont stick to the copper and you end up with a nice flat weld against the copper.
More clamping and welding.
And that was that side welded and floor pan tacked.
I cut a piece of wood and used that to keep the pillars apart for welding, as I wanted to remove the door and wedge.
To fully weld the floor pan I first wanted to remove it from the chassis.
So I rigged up the crane again to lift it off the chassis, but I needed to be careful not to bend the thing in 2, although it was now feeling incredibly rigid.
That worked well and I was able to remove the chassis and get the body back onto the rotisserie. :icon-biggrin:
Although the join in the floor pan on the passenger side was the better of the 2, there was one spot where the profile was slightly out and that needed some attention.
Nothing a little cutting with the angle grinder followed by a bash with a hammer and dolly wouldnt fix. :icon-twisted:
I welded up the inner sill joint.
I flipped the body back over and started welding the join up in the floor pan. To avoid distortion I started by putting a tack ever inch.
I then started joining the tacks up, randomly moving around so as to avoid putting too much heat in one area.
Until eventually it was fully welded.
Next top tip, never weld out to the edge of thin sheet metal as it will blow a hole in the edge of the panel.
And again a piece of copper really helps in this instance too.
I finished welding as much as I could on the bulkhead and floor pan joint and the next job was to repair the rotten sections in the floor pan.
I used a wire wheel in the grinder to clean up the rotten areas of floor pan so I could see exactly which bits to cut out.
Next I needed to remove the repair panel sections from the donor body.
I cut them over size to allow for trimming to a precise fit.
Bit of trimming later and my repair sections were all ready.
I cleaned them up and gave the underside a coat of the weld through paint.
And welded them in.
I put 2 grinding discs in the grinder at once.
The idea is to knock the top of the welds using the edge of a grinding disc(s) to avoid putting too much heat into the panels which is what could happen if I just went straight in with a flap wheel disc. Much better to take most of them down with a grinding disc and then just finish off with a flap wheel disc. :ugeek:
I repaired the only bit of rot on the new bulkhead next, the bit below the windscreen.
Cut the rot out.
I clamped a piece of steel behind to help hold the patch in place.
And welded it in.
The bottoms of the B pillars next, where they meet the sill.
I drilled the spot welds out and started to peal back the rotten section on the passenger side.
More trimming of rot later............
Cleaned up and a coat of weld paint later.
I cut a repair panel off the donor body, but it did have some surface rust on the inside so would need cleaning up, treating and painting first.
Bit of trimming later and it was the right shape and size.
I cleaned it up and rust treated it.
Followed by a coat of paint.
And welded it on.
Drivers side next which had some rot on the top.
And a dodgy repair below.
Began cutting and removing all the rot.
I'm not sure if this damage to the sill was done on purpose when they did the patch over the top or not, but it was a mess! :doh:
Cut some sections off the donor body, which again needed cleaning up and rust treating.
Patched the hole.
Painted it.
Tilted the body a bit to make the welding easier.
And welded the new sections on.
I gave all the bare metal and welds a coat of etch primer.
More soon. :thumbup:
Well done Ben! I admire your dedication and that you're keeping your focus and not cutting corners at this stage. I know I would be tempted by that little voice that says 'leave it, it'll be fine'…
When does Mini me arrive? :)
Thanks guys. :thumbup:
With the rot all removed from the front half of the body, it was time to turn my attention to the bottom of the rear quarters, which at this point I didn't think were too bad. :shifty:
I started off by having a poke and a scrape around what was that rust bubble on the bottom of the passenger side.
Which revealed a mountain of filler. :doh:
And a bad, previous repair. :thumbdown:
There was only thing for it, it would all have to be cut off and repaired properly.
I flipped the body over and began the cutting!
I decided I might as well do a quarter chop on the body, but I was never happy with the one I did on LJ's previous body as it looked too square and un-natural.
So I decided I would do this one on an angle and slope it from the bottom of the flare where the mud flaps mount.
Clamped a flare in position to work out where to cut.
I managed to cut even more rot out of the rear quarter using a dremel and an angle grinder with the guard removed and a worn down, small disc.
With all these bits removed, I had finally cut it all out of this side.
I just needed to square it up slightly and I could start patching it back up.
Made a repair section.
A quick coat of the weld through paint.
And welded it in.
Next I got to use a tool I bought last year and never ended up needing as the 78 project took over.
That let me create a curved section to fill in behind the tail light.
Which I then welded some spot weld tabs on.
Welded it in.
Bent some more sheet in my bench folder.
I folded up a small section to repair the end of the arch where I had cut the rot out.
Welded it on.
Ground down the weld where it needed to be flush, but left the rest of it as reinforcement, then gave it a coat of the weld through paint.
Then welded the outer section on to cap the bottom of the rear quarter off.
Ground all the welds down then smoothed them up with a flap wheel disc in the grinder, followed by a DA sander.
Then it was time to turn my attention to the other side.
I had already found a bit of rot and filler.
And this section of the panel was clearly made of filler.
It also looked pretty rotten around the other side and had another dodgy repair.
Started stripping it back.
It didn't look too bad at this stage, but it would prove to be much more rotten than the other side behind this panel. :doh:
Cut it open.
Started cutting and pealing my way through the rotten sections.
I finally reached a point where I had removed all the rot and cleaned it all up ready to repair.
The metal was very pitted on the inside of the rear quarter, but I didn't want to cut anymore out as I wanted to keep the section below the tail light. So instead I wire brushed the hell out of it (with the wire wheel in the grinder) and then rust treated it.
I also cut the 2 rotten sections out of the quarter panel itself.
Started welding new metal in.
Then grinding the welds down and painting them ready for the next section to go on.
I tried to copy the original design as closely as I could as obviously these C pillars need to be strong enough to carry the weight of the doors and this side especially as it has the bigger of the doors and the spare wheel. :ugeek:
After all that it was finally time to make the panel to cap the bottom of the rear quarter off! :dance:
Thought I'd give you a bit of a demo on this one of exactly how I do it.
First I make a cardboard template of what I need to create.
Then I draw around it onto the zinc coated sheet steel I've been using for the repairs.
Then I cut it out using the hand shear.
I trim as much of the waste off as possible.
Then finish it off with the tin snips.
Add some folds.
Realised I'd over bent one of the folds, so I put it back into the folder, clamp it in position and unbend it slightly.
I'd mistakenly forgotten to add a tab on one edge. :doh:
So I clamped it down on a piece of copper and welded one on.
And then I ended up with this.
I made sure the body was level on the rotisserie, then used another level to check this new panel I was welding on was at the exact same height as the other side.
And welded it on.
Welded up those holes in the quarter.
And bent up and spot weld hole punched my last new section for this side.
Ground and sanded down the welds.
Few more little rot holes that needed repairing in the C pillars.
I flipped the body back onto its side.
And chiseled all the bitumen insulation off the floor pan.
It was a horrible, messy, time consuming job. :thumbdown:
While the body was upside down I shone a torch up inside the sides of the body and spotted some rust with filler poking through it. :doh:
With the body flipped back around it was time to fix what I had spotted.
It looked fine on the outside and showed no signs of damage, but as soon as I hit it with a wire wheel in the grinder the true extent of the damage was revealed. :thumbdown:
Cut it out.
Made a cardboard template.
Folded up some metal.
Which fit like a glove.
Tack welded it in.
Then fully welded it, which I forgot to take a pic of. :icon-redface:
I removed the rear rotisserie mount and got it on stands.
As I needed to clean up the floor pan where I had removed the insulation.
And repair another rust hole that I couldn't get to with the frame in position.
The hole got a bit bigger when I found a bit more rot lurking under the paint.
I finished cleaning the floor pan.
But found a section of floor that was raised up slightly and looked suspicious.
Repaired.
I also found a little bit more rot on the passenger side B pillar.
With the body now the correct way up I could see how my repairs had come up.
The repairs behind the tail lights were looking good.
As was the quarter chop.
If I don't end up running the standard mud flaps that fit into these recesses, I may just cut them off and fiberglass them. :think:
After lots more sanding and cleaning it was time to get the body into the garden for painting! :dance:
My plan was to use the gazebo as a spray boot and enclose the sides with clear polythene, so that went up next.
I got a couple of coats of acid etch primer on the underside of the floor pan.
Then it was time to paint it in Raptor, which I had bought a 4 litre kit of.
While the Raptor was drying.............
I brought all my front inner arches in so I could select the best 2 for this project.
Decided on this 2.
Then the heavens opened. :angry-screaming:
It hadn't rained for 3-4 months at this point so I was pretty pissed that it would rain now. :icon-evil:
And with rain forecast for everyday for the next week.
The next morning after it had rained all night I made the decision to abandon the gazebo/spray booth in the garden and get it back into the garage. :shifty:
It was an absolute bitch to push/drag it back across the now drenched ground. :doh:
I got it back into the garage and got it dried off, it wasn't too bad as I had a tarp over the body so it was only a few spots of water inside the cab thankfully.
I removed the X brace from inside the body, so I could finish cleaning and prepping the floor pan.
I built a spray booth.
And as my garage is sadly part of the house and my wife is heavily pregnant I needed to setup an extraction system for the toxic fumes.
I didn't even want this blower, it came with the parts washer I bought cheap, but I'm so glad I got it as it would prove very valuable with this paint work. :clap:
I also duck taped the loft hatch and sliding door into the house to keep the fumes out.
I gave the body a coat of etch primer.
Then masked off the areas of body I didn't want any Raptor going on.
And gave it a good coat of Raptor. :icon-cool:
As the Raptor being a 2k paint is particularly smelly and harmful, I also setup my big industrial fan to help blow the fumes outside.
Next I removed the rotisserie.
Which meant I finally had proper access to the new bulkhead to prep it for paint.
After sanding and cleaning the bulkhead masked the edges of the Raptor paint on the floor pan and taped polythene down to protect it.
Mixed up some 2k primer.
And gave the whole thing 3 coats. :icon-twisted:
I mixed up some body filler the day after the primer went on.
As there's a few areas that just need a little wipe of filler, not much, I don't want it very thick as it will only crack when I go off road, but a little thin wipe here and there is needed. :shifty:
These areas where I've repaired needed a little bit.
And that's pretty much where I'm up to. :sleeping-sleep:
I'm in the middle of filling and sanding now, which I'm hoping to finish tonight.
Then I will give it another couple of coats of primer then sand the whole thing down with wet n dry and get it silky smooth ready for the Mid Night blue top coat later in the week.
Hoping to have the body back on the chassis this weekend. :icon-cool:
I think I might have lost heart and scrapped it after opening up that second quarter Ben. This sort of stuff is a psychological nightmare.
Sir, you have some wicked skills (and patience). Well done. Also, good luck with the new addition when he or she arrives!
Rich I wanted to scrap it long before I got to that point! :lol:
I think if I had had it dipped and seen what was lurking under all that paint and filler, then I would almost certainly of scrapped it! :shifty:
I'm still not 100% happy with it as I know there is still rust in some of the seams that I haven't been able to get to. :doh:
So I know this body wont last forever, but then it must be getting on for 10 years since it was resprayed last and despite the absolute bodge job they did on it, it still looked pretty good. So I'd like to think I might get 15-20 years out of this body, hopefully. :think:
Its a bit annoying that I didn't spot how rotten it was, especially as I spent a lot of time looking at it and even pushed a magnet all over the body. :icon-redface:
I knew it needed some work but had no idea just how much. :doh:
Oh well, its going to look awesome when its done and will make an awesome rock crawler when its finished! :icon-twisted:
3 weeks tomorrow my son is due and I've got so much more work to do to get this 70 back together before then! :crazy:
Apart from being disheartened, it's a great feeling to see all that new metal going in and knowing you've hit 99% of the lurking rust.
I'm always a bit concerned with those lower quarters collecting more water and condensation. I'm presuming you've made adequate provision for drain escape holes. Protecting them with paint is no easy feat either, after you've formed them in a seam or drilled them out.
Great work as ever Ben, keep at it, 'cos you really have achieved a major milestone on the project. :thumbup::clap::clap::clap:
Well impressive
I would have thrown the toys out of pram and been reduced to tears by the enormity of the dealing with the rot
Looking great Ben.
Something you might already have thought to do, after you've finished with the primer use a black aerosol and dust coat the body, when you wet flat it any low/high spots show up, when the black has gone the surface should be nice and smooth.
