Lexi.
Lexi has continued on her spree of destruction and finally killed her bed this week!
This is what I got home to last week.
Its hard to be mad at her though when shes that cute, so she still got a treat.
We gave her an old bath mat to sleep on for now.
But it doesnt stay in her bed for long, yesterday I found it in the garden!
Complete with mouth holes!
Breakfast in bed!
Lexi and I went to the pet shop this week to get her some more food. She slept most of the way there.
The staff loved her in the shop!
We got her a new toy which will hopefully amuse her for a while when we are out at work.
I filled it full of treats and it kept her amused for hours, she loves it!
Bec and I got home from dinner the other night to find Lexi fast asleep in the middle of the couch. She had obviously jumped over the child gate and escaped!
Fearing the damage she could do if she got out and we were at work all day, something needed to be done.
The trouble was it wasnt just the gate, the entire dwarf wall wasnt much higher!
Thankfully I still had lots of pallet wood left.
So new perimeter defenses were hastily knocked up!
They simply drop in place over the wall.
Yamaha WR450f.
Friday was my last day at work and they sent me out with a guy I hadnt met before, called Sam. We got chatting and Sam was telling me he had moved up from Melbourne himself a few years ago and hes into motorbikes and has an enduro.
I said I'd be keen to get out for a ride sometime and he said he would too.
So the very next day, we met up for a ride and he showed me around the hinterland heading over the Great Dividing Range and South into New South Wales.
We rode through the Currumbin valley.
What a magic spot! I must bring Bec her for a swim when the weather warms up a bit!
Amazing views as we dropped down out of the mountains.
We rode all the way South to Nimbin where we stopped at the rather funky looking "Bringabong" cafe for a drink.
It was easily my most enjoyable day motorbike riding ever! No off road riding, but all nice fast twisty roads and we swapped bikes a few times which was fun!
Sams bike beats mine top end but its no where near as fast as mine up to a 120kmh! The WR450 is savage and it sounds so nice with the aftermarket exhaust!
Fuel range is an issue with my bike and its little tank. I took a pic of my mileage when I had just filled up.
Then again later when I filled up and another pic of how many litres I had put in, so I can work out exactly how many K's I'm getting to a tank.
It was an amazing day and I rode about 300km's in total.
Decided to drop the oil the second I got home while it was nice and hot.
It was pretty clean but I know how highly tuned these engines are and how important regular maintenance is on them.
I also needed to tension the chain as it had gone a bit slack.
Which had increased the wear on it and resulted in a bit of swarf around the front sprocket.
The rear tyre desperately needs replacing!
Its scary to think about some of the speeds we were doing, when I saw just how bad the rear tyre is.
I also spotted that its not even designed for road use.
So I need to get a new rear tyre before I ride it again.
Thinking of either a Dunlop to match the front.
Or a Bridgestone.
I left the oil draining over night, then the next day re-filled it.
Decided to start my own service record so I can keep track of what needs doing, when.
Decided a stand to sit the bike on for working on it would be useful.
I will probably buy one of the foot operated lift up ones at some point, I did have one but I sold it when I down sized to emigrate.
I found a pallet by the skip at work last week which was made of some nice hardwood.
Came apart really nicely so I managed to harvest all the wood from it.
Decided that would be the perfect wood to make a stand with.
Did some fancy compound mitre cuts on my little saw.
Took all the rough corners off with a block plane.
Screwed it all together then gave it a quick buzz over with the belt sander.
Works perfect!
With the bike now properly supported I could check the chain and adjust it.
I've partially stripped it down at the moment as I'm trying to fix the indicators that have stopped working.
There is a flasher can that was hanging down below the tank and not secured to the frame which I suspect could be the problem.
Car Fire.
Driving home from dinner the other night we found a car on fire at the side of the road!
The police quickly turned up, followed by the fire brigade.
LJ.
My neighbour had asked to borrow our trailer.
Not a problem I thought, will just back LJ up and push the trailer out.
Only LJ wouldnt start as the batteries were too flat.
Well I tried everything! I tried jumping it off the Astra which I parked the other side of the gate. Tried jumping it with the Astra and another battery, still nothing!
I even tried pushing it but as we had a day of torrential rain a week or so ago LJ had sunk into the ground a bit, so I jacked the wheels off the ground and dropped it back down on planks of wood, but it was just too heavy for me to push.
I then discovered that the batteries had just about got enough juice in them to power the winch.
So I ran the winch rope under LJ and out the back, through a snatch block attached to a little tree and back to LJ.
And slowly out she came!
Supervised by Lexi!
Because of the angle of the pull the rope did rub against the tyre slightly but it didnt do any damage.
Eventually it was out enough for me to get to the trailer.
The batteries finally completely died so the winch rope just got wrapped around the bullbar for now.
So it just goes to show that if you get stuck some where it is possible to winch backwards with a front mounted winch if you have to!
I've winched backwards before with the winch rope going around the car, using 2 snatch blocks off 2 trees to the side of me. But never straight underneath like this.
Yesterday I removed the batteries to get them charged up individually.
Normally I dont even lift the bonnet to charge them and just plug into the anderson plug on the bullbar with my lead I made up which goes straight to the battery charger.
I did charge them like this a few weeks ago, or atleast I thought I did!
Now I'm thinking the battery charger must have detected one of the batteries was stuffed and just switched off. Then I came along, saw the battery charger had switched off and thought beauty their done!
Anyway............................
Got them both on charge.
After having them on charge all day it appears one is OK but the other one is stuffed.
Wish now I had bought a pair of yellow top Optimas while I was still at Piranha and could get them at cost price.
Oh well, something else to add to the wish list!
Work.
Friday was my last day working as a glazier. I actually quite enjoyed the last week as I was out on my own fitting, but I knew I was never going to make much money doing it due mainly to the constant issues with products being measured wrong/made wrong/damaged/lack of communication etc. + Its not really what I want to be doing.
So I'm happy I've left and I will take a lot of positives away with me. The main thing I learnt was the easy way to do perfect silicon work!
Having worked with silicon sealant for over 10 years I wish I had known the easy way to do it from the start, it would have saved a lot of hassle and mess over the years!
The secret to good silicon work is not soapy water as some people use and I used to use myself.
Its mentholated spirit which is mainly ethanol (alcohol) so evaporates really quickly unlike soapy water.
So you run your bead of silicon along what your trying to seal (in my case between the shower screen and the tiles) and you dont worry too much about applying too much.
Then using a spray bottle of metho you spray a shit load of metho all over it, you really cant over apply it!
Then you run your finger down it removing a lot of the silicon as you go and wiping your finger clean on a rag to remove the huge blobs of silicon that come off.
Give it another good spray of metho and one more final wipe down with your finger and you have a perfect result!
Almost forgot..........................
I start the new job 2 weeks today!
*Edit. I really dont know why that pic is at the bottom of this update, everytime I edit and delete it, it re-appears! Same thing happened last time I did a big update!
Crispin?
