Well it's a new morning as they say. Nick and I covered the remains with a big sheet so at least I don't have to look at it. Thanks for all the advice chaps. I shall be speaking to Flux today about their policy and if it's clear that I can buy the salvage, then I shall be doing so I figure. If you look at the likely cost of that off set against the fact that I am bound to want a locker, spare wheel, abs sensor, window winder, CV joint etc, it has to be worth keeping those parts - with a locker being £400 straight off. Add to that a set of spare top quality diffs, drive shafts, callipers, discs, handbrake mech, autobox and TC plus transfer box?.... It makes sense. I shall have to pay £250 excess anyway. I will certainly be pulling the injectors,. whatever. I will have them rested of course. They actually look fine, but there are springs and things inside them. If they still work then that's a bonus.
It is a real shame as it was running absolutely beautifully.
Incidentally, several of you have mentioned the added electrics, well they were all declared to the insurer, but in truth, all I did was connect a winch and a pair of cables to the rear battery. I hadn't actually messed with anything else. The rear Cyrix was protected with a fuse so that if it was running and there was a short, it would be protected. When I got home, the rear battery was still powering the fridge and the inverter. The fuse was intact. So there'd been no activity there. As the shrouding melted on the main cable they could have touched together under the bonnet which would have shorted the main battery. But, as the battery had gone along with everything else, it's likely that it went before the cable did. GV was a completely above board truck and I don't think that even an air crash investigator would be able to see what happened here. The black box has melted too!
I shall have to call the next one The Phoenix, eh?
