My new overland project
Olazz Sep 6, 2017
Replace rally stickers or not?
Poll closed Jul 16, 2018.
  1. Yes, keep its racing heritage
    5 vote(s)
    38.5%
  2. No, it now a motor caravan
    7 vote(s)
    53.8%
  3. Too boy racer pretentious nonsense
    1 vote(s)
    7.7%
  1. Paddler Ed
    Paddler Ed Well-Known Member I am in australia
    1,771
    439
    83
    Garage:
    Map
    Our local brewery worked out how much more beer they could ship if they used cans instead of bottles - the weight saving over a pallet was quite considerable, and also packed smaller.
    On a similar vein, wine in a box and goon sack is lighter than the glass bottles to carry the same amount...
  2. Chris
    Chris Super Moderator Supporter I am in europe
    16,574
    3,500
    113
    Garage:
    Map
    Not sure that you can get Chateau Nuits San Wogga Wogga in boxes.
    clivehorridge and StarCruiser like this.
  3. Dave_S
    Dave_S Well-Known Member
    998
    340
    83
    Jeez, Lazz - just read your site updates - what an absolute nightmare. Glad you are getting things back on track now.
  4. StarCruiser
    11,661
    4,670
    113
    Garage:
    Map
    Cuvée Reservé
  5. clivehorridge
    14,612
    4,540
    113
    Garage:
    Map
    Whilst the mock up in the vid appears to be sound engineering, was a ram operated pivoting lift/securing cradle considered Lazz?
    It would do away with the need for those heavy vertical control stanchions and thus a fair chunk of the additional weight, and reduce the action to one rotating function instead of the two separate (vertical & horizontal) functions proposed. Radial forces are often much easier to deal with lighter gauge components than those necessary to deal with the combined leverage forces created during separate vertical & horizontal movements.
    Please don’t take this the wrong way, the whole project is stunning, just trying to offer a constructive thought process.
  6. Olazz
    Olazz Well-Known Member Supporter I am in zimbabwe
    1,397
    474
    83
    Map
    Clive, I'm no snowflake boet, I welcome any input.
    The 5 issues to had to solve:
    To limit rear overhang on box.
    How to get motorbike in/out the garage. (150kg)
    How to get spare tyres on/off rear door.(100kg each)
    How to lift garage door with weight of tyres. (300kg)
    How to seal the rear door from dust.
    I didn't want the bike and tyres stored on a platform outside on a chassis-mounted hydraulic lift.(overhang)
    So a slide out drop down as per video, addresses all of these. The weight of a ram, pivoting hydraulic lift, is circa 500kg and doesn't solve the issues above.
    The total weight of the current design including all the hydraulics and rams is ~600kg. So very little in the overall weight, compared to the pivot chassis system. The problem is not the mechanism, as any mechanism would have added 500+kg. It was the decision to carry a motorbike on the truck. That one decision has created an extra 750kg payload.
    I don't have a problem with weight limit, as the truck's GVM is 18,000kg. All up, I'm now close to 11.5t.
    If you've got a design that can accomplish all that then I'd be delighted to hear.
    clivehorridge likes this.
  7. Dave_S
    998
    340
    83
    I see K2 have gone into liquidation...
  8. StarCruiser
    11,661
    4,670
    113
    Garage:
    Map
    Doesn’t surprise me given the catalogue of errors and incompetence in this build. Really sorry to read this Lazz but pleased you’ve now moved on and clearly found someone capable of completing the build. It is unfortunate that there are people that purport to be experts in their field that clearly make a hash of things by operating way outside their capabilities.
    May your troubles be over.
    Heaumey and clivehorridge like this.
  9. Olazz
    1,397
    474
    83
    Map
    As it's in the public domain... Yep they have as a result of my legal action. I had little choice in order to recover money from them.
  10. Dave_S
    998
    340
    83
    Fair enough, Lazz. Good luck with the rest of the build. Look forward to seeing the finished product! :)
  11. clivehorridge
    14,612
    4,540
    113
    Garage:
    Map
    Erm, no.... in short :lol:
    My idea would have only got the bike into the truck and supported it during transit.
    Sorry for all the bother you’ve had Lazz, clearly you’re getting there :thumbup:
  12. Olazz
    1,397
    474
    83
    Map
    New entry step and Teak floor in. Bottom of the door frame, just another bit that was butchered by K2, but managed to salvage it.
    Bed base and frame now in; this time the correct size of 1.4m x 2.3m. It is also now the correct height, so when the mattress is fitted you can get access to the window lever. K2's version was only 1.1m x2.4 and the mattress was 6" over the bottom of the window, so you had to move the mattress to get at the window lever!:angry-screaming:
    Re-sited 55l LPG tank (Lavatory + Hob) now out of harms way and correctly fitted. Will have a cover plate to protect it from damage.
    How the box should have been build the first time. Metal frame support to stop torsion twist and stress de-lamination. If the truck tips over it won't just collapse like wet cardboard now.
  13. Chris
    16,574
    3,500
    113
    Garage:
    Map
    He knows his stuff does Ian. Getting there Lazz, getting there.
  14. nick_the_fish
    nick_the_fish Well-Known Member I am in great_britain
    677
    299
    63
    Map
    With all the preplanning in the world you'll never think of everything. Nice detail.
    Love the Teak floor/ entry step combo - looks fantastic.
    @Olazz are you sure that the gas tank can be installed like that? I've just got a Gasit Tank to put on my truck which looks identical (albiet I can't see the valves etc in your photo) which says it needs to be installed the other way up due to the gas pick-up inside. I'm sure you've got all that checked and squared away but just thought i'd ask - it is gas after all!
    Looking great
  15. Olazz
    1,397
    474
    83
    Map
    Deleted post
  16. Olazz
    1,397
    474
    83
    Map
    Yes, loving the floor too. Good spot with the gas tank Nick. It will be installed hangars up. It was bolted that way for initial measurements and alignment with the rear chassis cross member( had to be moved) and a grey tank that will go underneath. It was simpler to line up sitting on the hangars.
    The re positioned rear cross member.
  17. guruvetim
    guruvetim Member I am in zimbabwe
    151
    76
    28
    Map
  18. Olazz
    1,397
    474
    83
    Map
    I have deleted the post above as the text is automatically creating a hyperlink .... I have tried several times to delete and retype it, but every time I add a picture it also hyperlinks the text. There is no connection between the pictures and text, so I don't know what it's doing that.
    Fed up with doing this, which is why I stopped updating here too often. I've ranted about this before . I've better things to do with my life than keep uploading content that doesn't work.....:rage: Grrrrrrrrrr
  19. Olazz
    1,397
    474
    83
    Map
    Not sure about a grand unveiling Tim, it's not that grand! I will also rebook Devils pit, that I did last year, and people are welcome to come for the day and drive... better add, not my truck of course, but your own!
    https://www.landcruiserclub.net/community/threads/devils-pit-4x4-course.150898/
    guruvetim likes this.
  20. Chris
    16,574
    3,500
    113
    Garage:
    Map
    Clearly operator error. Hey you can't deny us the build story Lazz. We're all waiting eagerly.
Share This Page
    Dismiss Notice
