Speed sensor
vencel
hungary
Hello,
Does anybody know where is the odometer/speedometer sensor on the HDJ100?
Is that easy to reconnect?
My LC100 suddenly stopped showing the actual speed so I have the engine signal light ON as well as the trip information does not show the actual fuel usage.
Thanks!
Thanks!
At the rear end of the transfer case.
Thanks a LOT for your quick reply. Is it easy to reconnect or shall I take it to a mechanic?
Forgot to mention it is a 2004 HDJ100.
Reconnect?
If it's unplugged at the sensor it is easy to reconnect, but how likely is that...
Cable fault (e.g. at the plug)? Combination Meter (instrument panel)?
It was working before I took it to a mechanic to change the timing belt and all oils and filters (except auto transmission oil).
I guess they disconnected it and have not reconnect it correctly so I was wondering if it will be a simple fix and perhaps I could do it myself.
Have a look. It's easily accessible at the very back of the transfer case.
