Beau
- Jan 28, 2011
If engine dies when you're still on start but starter is off, doesn't this show it's probably a mechanical issue? Have you checked the injectors for fuel when cranking, this will determine if the pump is sending fuel. Then check the glow plugs like I suggested before...
These trucks will struggle to start if compression is poor as well.
