TLC HJ61 total reconditioning
Sharing some of my adventures.
In this instance, I decided to replace the turbo assembly. It did have an off spec clearance. I also replaced the universal joint of the steering column both the upper and the lower. The waste gate actuator also malfunctioned. also repaired the kinks and dents on the oil pan. In this way, I got every leak covered.
I also upgraded my converter (24v to 13.8v) from the previous 25amp to 85amp.
Looking good Oding. I can’t make out what’s in pic 7. Looks like bubble wrap but I can’t see where or why? :think:
Ah, ok so sound/thermal insulation then. Got it! Thanks.
