underbody treatment
jonnyboy54321 Jan 14, 2016
  1. Shayne
    Shayne Well-Known Member Guru
    11,616
    3,756
    113
    Map
    Where we are stuck is the quality of product comes secondary to application , without a good key and an airtight finish nothing will last .
  2. frank rabbets
    frank rabbets Well-Known Member
    4,656
    990
    113
    Map
    Couplertec.....there you go 2 more Quacks. If only part of the car gets wet it cannot work....so doesn't.
    I assume when a new ship is built the steel hull is cleaned and painted to the best ability but I think they still rust.
    The salt on our roads is a big problem. Even when dry on the car the salt reabsorbs water when the humidity in the air increases so the car will rust away even sitting in the garage.
    When I used to cut metal back to very lightly rusted areas to gas weld new steel on I could smell chlorine so I think salt must have still been present. I don't know what happened to the sodium lol.
  3. StarCruiser
    11,550
    4,594
    113
    Garage:
    Map
    Either way, Couplertec either works or is an elaborate hoax. Until I have personal experience, I'll keep an open mind. After all there's going to be a lot of opposition to it from paint and protection manufacturers if it actually does work.
  4. jonnyboy54321
    jonnyboy54321 Well-Known Member I am in great_britain
    776
    22
    38
    Garage:
    Map
    Another was viewed for me yesterday. Worse than the last one.
    Search now expanded to included non-land cruisers, very reluctantly. Mrs JB has decided on what she wants (E class convertible, with me having a 4x4 which we/she uses when seats needed), and there's a 0% deal on at Merc main dealers till tomorrow. So will need a 5/7 seater to replace the galaxy asasasasasap. Not driven the E class yet and its damned snowing.
    Damn.
  5. chapel gate
    chapel gate Well-Known Member Supporter Promoted Company I am in england
    3,467
    2,032
    113
    Map
    Please, sit youself down in a dark room and have a good think about what you've just said...
  6. chapel gate
    3,467
    2,032
    113
    Map
    How long would you be thinking of keeping the 120 for?
  7. jonnyboy54321
    776
    22
    38
    Garage:
    Map
    3 years.
    Needs to be "nice" enough to do 3/4 weeks in Europe/trips up north etc.
    Pal just brought round his L322. They don't half have their problems, but they are quite lovely, and drive very nice too.
  8. Shayne
    11,616
    3,756
    113
    Map
    I seen a good rangerover once it looked brand new apart from the fact it was on fire in a motorway service station carpark !
  9. chapel gate
    3,467
    2,032
    113
    Map
    If your only keeping it for three years and your happy with the rest of the motor/price is right/ needs no welding. id be tempted to get it then.Id spray underneath with diesel and then engine oil, repeat yearly.
  10. clivehorridge
    14,490
    4,387
    113
    Garage:
    Map
    I'm not necessarily disagreeing with others, but I do side with Frank's use of oil.
    I squib oil into my chassis boxes, and when I came to remove and replace the ARB front bumper a year or so ago, the visible interior of the front chassis box (where the ARB mounts) was oily up the sides and on the soffit (underside of the top).
    IME, oil creeps and the rough nature of surface rust actually enhances the capillary action of the creeping.
    There's no way to treat the interior of closed box sections other than an acid dip or similar with a zinc dip to follow, so for regular annual maintenance (in the summer) I squib oil.
  11. AndycruiserguyLomas
    4,202
    1,401
    113
    Map
    Collie Chassis after acquainting it with an aggressive wire wheel on the angle grinder, Curerust, etch primer, matt black and smooth Hammerite. The inside was coated with engine oil applied with as syringe through all the holes in the chassis sides. Done end to end so it can be done. I used all my old aerosols up but probably would have cost about £80-90 to do.
    I did all the under floor in a similiar fashion but finished it off with Waxoyl based underseal.
    It might resist the salt a bit now, as the Collie is my winter driver till spring.
  12. Shayne
    11,616
    3,756
    113
    Map
    Excellent Andy do you wanna do mine :pray:
  13. stumog
    stumog Well-Known Member I am in england
    3,392
    587
    113
    Map
    Mines booked in first shayne no question jumping
  14. AndycruiserguyLomas
    4,202
    1,401
    113
    Map
    You either sit and watch telly at night or get in the garage and get things done. This is why I don't have a TV at all. It took me about 3 weeks to baseline the Collie and get it towards where I want it.
  15. jonnyboy54321
    776
    22
    38
    Garage:
    Map
    Looking good Andy
  16. Shayne
    11,616
    3,756
    113
    Map
    I hear that Andy i am determined to have a garage by next winter so i can take things apart and leave them apart until it's finished .
  17. stumog
    3,392
    587
    113
    Map
    Yeah need a garage this year it will happen
  18. lc 120
    lc 120 Well-Known Member I am in uk
    451
    97
    48
    Map
    Just booked mine into 'Rustmaster' for this Friday...:icon-biggrin:
  19. frank rabbets
    4,656
    990
    113
    Map
    Certainly does hide the rust Andy :icon-biggrin:.
  20. Sag
    Sag Well-Known Member
    756
    77
    48
    Map
    Good job there Andy and if you do get board well we can keep you busy
Share This Page
    Dismiss Notice
