Hi Roger, yes indeed it looks very high up. The main body of the new gearbox sits 240mm above the chassis rails. The length is such a lot more too.
I've done some measuring tonight regarding the top line of the bell housing to the fj45 passenger side gearbox mount.
On the 2f from the top of the bell housing to the underside of the mount is 260mm and the 30mm for the thickness of the rubber bush to meet the chassis equals circa 290mm above the chassis rail.
I've leveled the new gearbox so the lines on the casing are parallel with the chassis and it measures 285mm top of bh to the top of the original lower mount bush.
The comparison between the top of bell housing is very similar in height between the 2 gearboxes but the overwhelming height of the h151f is remarkable and it will eat into the cab space quite a lot.
I think to fit the knackered 1hdt block in next and fit the viscous fan with the original radiator that came with it to see how parallel the radiator is to the viscous fan. Then make a decision, it would be quite straight forward to add a section of box metal between the gear box mount and the lower side of the chassis..
Can picture that I going to have to cut the floor of the cab so that it fits around the gearbox. so already planning to trial fit the cab after fitting the parts above.
Should be some pretty interesting pics coming up! Lol
