LJ.
Bec started her new job at my hospital and her new boss has agreed to let her have time off for the Simpson Desert World Record Attempt!
So I'm now busy getting LJ ready.
I've ordered some much stiffer rear springs from Dobinsons which are being made to order as I write!
I removed the Superior Engineering adjustable panhardrods off RJ as I want to try and fit them to LJ when the new springs go on.
Next job was the aircon install.
Its now over a year since I got back from Europe with suitcases full of aircon parts, so it was about time I got it finished.
RJ had aircon when it left the factory, most of it is still fitted apart from the engine bay components. But I did get a pump and a load of bits of pipe with it.
Which got me thinking, I wonder if this old pump would bolt onto my 1KZ engine.
Amazingly it did and it looked like it would work.
The only issue was connecting the pipes.
The one pipe bolted up perfectly.
But the other was going to need some work as not only did it not have the correct angle on the fitting, the hose wasnt long enough.
The angle on the fitting could be made to work, just, but it wasnt ideal.
It was far too short though.
I decided to do the job properly I would have to get a hose made and I thought the cheapest and easiest thing would be to just get a new piece of hose crimped onto my fittings.
So I worked out how much longer it needed be.
Carefully removed the old crimps.
Decided to bend the one fitting slightly to angle the hose away from the rad.
So I heated it up and bent it around a socket very gently.
I went to 2 local hose makers and neither of them had the correct crimping tool or crimps to use my fittings.
So I had to get a new hose made.
They had to get a local TIG welder to weld a new threaded male end to the fitting that bolts to my pump.
I picked up a new belt, well actually I picked up 4 in total and the first 3 were all the wrong length.
The joys of fitting a pump to an engine it was never designed to fit onto.
This was the 4th and final one.
I tested the pump using a battery to see if the magnetic clutch was engaging when it got power, which it was.
And then I bolted it all up ready to get it gassed up.
The drier would be getting replaced, but apart from that it was all good to go.
An hour or 2 after dropping it off at my local aircon place they called me to say that they needed to convert the system from R32 to R34 (I think thats the correct numbers) as they couldnt get their equipment onto my fittings.
There was a small cost increase, but it had to be done so I told them to proceed.
Then an hour later they call me with some bad news. They have snapped off one of the fittings and stuffed my fitting that I had welded up and that was the only pipe/hose I didnt have a spare of.
I went down and saw them and they were saying I should go to a wreckers yard and try and find another fitting, or go and get another hose made up.
So I suggested why not weld a new fitting over the hole where they had sheared off the old fitting.
I got a fitting off them and raced down to BOC and got a bottle of argon for my TIG.
Because alluminium is such an amazing conductor of heat, its vital to have components really well clamped to avoid distortion.
I shot back down and gave them the fitting and waited patiently for news of how they got on with it.
I was worried about the pump as I knew it had been off of a vehicle for many months and thats not good for pumps. It even states in the FSM that if you intend to store a pump for a while you should seal some gas in it.
Anyway......................
An hour later I got a phone call to say it was all finished and working like a dream!
New drier.
New fittings.
I pulled the airbox out as now it was all working I could tidy up all the wiring and change the pulley bearings.
Removed the pulleys from the pump and belt tensioner.
Pressed the old bearings off.
Took the old bearings to my local bearing shop.
Fitted the new bearings.
I could then bolt it all back together.
And thats the aircon install complete!
I've got some service work to do before the trip so I finally treated myself to a proper seal driver kit, I thought for the sake of $30/£15 delivered, off ebay, why the hell not!
I also picked up some light bar mounts that were on sale and very cheap.
Nice chunky billet alluminium ones.
As I'm thinking of putting the light bar that came with RJ on LJ.
Speaking of RJ I spotted this pic last week from a car show in Germany of a nice soft top 70 series, this one is slightly longer as its a medium wheel base but otherwise its an identical model to mine.
Thinking mine would look cool in black.
I also found some pics of the duel cab ute I want with style sided tub, OK this one is a petrol and doesnt have the snorkel, but it is in the Midnight Blue colour I want.
We've just got to do some house flips first then I can buy one.
The Bike.
I've been out for a few rides lately.
I went for an on and off road trip on my own and rode Duck Creek Road.
The pink route this time.
Rode it the opposite direction to when I drove it in LJ, so up to the National Park first.
Then down Duck Creek Road.
It was quite wet in places.
They have installed hundreds of meters of wire, star pickets and signs since my last trip to stop people going off piste, which was nice to see, as like strata Florida in Wales it was looking a bit of a mess from the dick heads who wont stick to the track and have to go off playing.
Fantastic weather for a ride!
Then last Sunday I went for a day at QMP with my work mate.
It was a great day but I came off a lot!
Almost hurt myself quite badly coming back down a steep rocky climb that I failed to get up when the bike came down on top of me and pinned me down over a big rock.
All good though and the bike was soon clean and back in the garage.
Did break another clutch lever early on in the day, but just carried on with the broken lever.
So last nights job, now I have TIG gas, was to repair some clutch levers.
One side done.
Then flip it over to do the other side.
I'm going to get a little bag to bolt to my rear fender and I will carry spare levers and some tools in it.
Lexi.
Shes growing up fast and is loving our weekend trips to the beach!
Shes also had more play dates with her best friend Chilli.
We went to Byron last weekend which we all loved!
This was Lexi's first trip to Byron, we must get back down for a camping trip some time soon.
And thats pretty much it really guys.
I'm still planning the work I want to do on RJ and I've hopefully sourced a load of the parts I'm missing for the body and interior. The engine conversion is on hold until after the Simpson trip, but then I want to get stuck into it.
Next weekend we have a family camping trip to a big motorbike park with my work mate and his family and this weekend I'm going to buy some more goodies for the bike and get it ready for the trip.
