OK....................................
The good news is I managed to get the phone working enough to get all the pics off it for this update.
The bad news is I couldnt fully fix it, so its had to go in the bin and a new one has been ordered.
So.............................update time.
With these standard engine mounts.
Bolted to the engine, the original chassis mounts were 45-50mm too far forwards.
I cut some 80mm x 10mm flat on the cold cut saw.
And drilled some 10mm holes in it on the drill press.
As I want these engine adapter plates to be fully bolt on to avoid welding the chassis, they need to bolt to the original chassis mounts and then extend across to the engine mounts new position.
It looked like they would work OK.
A bit more drilling to make the other one.
And I had 2 plates.
Welded M10 bolts in a hole in each plate and gave them a coat of paint.
On the other side the bolt needed to finish flush to allow the engine mount to be bolted over it.
Bolted in position.
Power steering pump is close but its got enough clearance and I want to elongate my holes slightly and move the engine 3-4mm forwards anyway, from this position which will result in more clearance in this area.
Other side.
All thats left to do on them is elongate the holes slightly to move the engine mount forward sightly on the adapter plates and I'm going to make some other brackets that will pick up on the very rear engine mount bolt and go back to the chassis diagonally to reinforce it and make sure I'm not putting too much strain on the original chassis mounts.
I looked at the rust below the windscreen next.
Pulled the screen out.
And managed to break it in the process.
I could now see the extent of the rot.
It had that much sealant around it that they had blocked one of the drain holes below the screen.
I'm picking up the remains of that red LJ70 wreck that I pulled a load of parts off at the start of this thread, this weekend and I will cut out a section of that windscreen surround to weld into to replace the rotten metal.
I've been cleaning lots more parts up.
Gave them all a coat of the rust killer/primer and hung them up to dry.
I also cleaned up all the front end panels ready for paint.
The passenger side guard looked OK but it had a bit of surface rust where it bolts on.
After cleaning all the small spots of surface rust off, I cleaned the big areas up on top of the guard where surface rust spots were starting to come through.
I've been using this rust killer/convertor product lately.
It works well but its bloody strong stuff. I spilt some on the bench and by the next morning it had eaten all the mill scale away and left a nice oxide coating on the steel.
Removed all these bits from the radiator support panel.
And started getting the panel ready for the wire wheel in the grinder and rust killer.
I removed some of the bottom bump strips next off the doors, these will need the paint removing from them and re-fitting after the respray.
Found 2 scrapers worked best to cut through the adhesive at each end and pop all the trim clips off.
Started sanding the blue primer off.
Which revealed at some point, when it was still its original paint/colour someone painted a horrible green stripe around it.
I also sanded the front passenger guard down.
And a bit more on the door.
So the RJ70 sold.
And they came and collected it.
Then I shot down to Sydney the next day.
We left at 12pm and drove for 7 hours and camped at the side of the motorway. At 4am we were up and on the road and I then drove all the way through until 9pm that night when we finally arrived home.
The next day I could unload the car and inspect the new parts.
This is the Australian made second hand MIG I picked up.
Only a small one but thats all that is required for thin sheet work and I have my TIG for anything really thick.
Set my gazebo up in the garden to keep the sun off me and got to work cleaning up the rest of the panels.
Even treated myself to some new wire wheels for the grinder.
The passenger side inner guard required the rot to be repaired.
Rot is like cancer and the only way to cure it is to cut it all out.
Cut through the first layer of steel.
I decided to try and treat the second layer of steel below with the new rust killer, seen as I was using it on some other bits anyway.
These are the other bits that got a good coat.
The next morning it looked OK.
But I decided I just wasnt 100% confident that the rot would not continue to eat away at the metal.
So I cut it out.
And began patching it with new 2mm thick steel.
TIG'd it all together then smoothed the welds down.
Snorkel next!
I needed to drill all the mounting holes in the new, rare and valuable guard.
Found the instructions and template.
Template taped in position.
There are 4 tools that are essential for a neat, professional, snorkel installation and they are:
-An automatic center punch, so you dont risk damaging the guard which is very likely with a traditional center punch and hammer.
-Step drills which work amazingly well in thin sheet metal as they wont bite and twist the thin panel like a conventional drill bit and they are also much quicker so dont put any heat into the panel which can damage paint/warp the panel.
-The correct size hole saw for the snorkel being fitted. (You would be amazed at how many people bodge a snorkel installation by drilling a series of holes in a circle for the main snorkel hole and then try and join them up with tin snips.
-And finally a de-buring tool to run around the edge of the holes you've made to clean off any of the sharp metal, ready for a lick of paint to protect the bare metal edge from corrosion.
So I drilled my bolt holes which the bolts will go through to attach the snorkel to the guard.
Followed by my first big hole.
Followed by the second.
Then I cut out the metal between the 2 with a thin cutting disc in the grinder.
And the snorkel bolted on perfectly.
Next I needed to make a hole on the inside of the guard to connect it to the airbox.
When I fitted it originally, to LJ, it was a little bit rough where it came through the inside of the guard as I made one big hole with the hole saw but then had to make it bigger with a grinder.
*No pic of this new, nice neat hole sadly, as this is the point where the Iphone died.
I got some more parts painted in black enamel.
Anti roll bar/sway bar.
And a transmission guard, these came on early Australian spec LJ70's and RJ70's (not sure about other markets).
But all the later square headlight 70's only got a tiny flimsy little plate that offers little in the way of protection, where as these guards are really solid.
So both my square headlight 70's will be getting these guards.
I bolted those bits on and the next part to bolt on was the freshly painted steering shaft.
I turned my attention back to the body work next and in particular the rot in the rear quarter panels.
This side first.
Marked where I needed to cut.
Rotten metal removed.
Lots of rust to clean up.
Cleaned up with a wire wheel in the drill and grinder.
Followed by a coat of this stuff.
I took some measurements and marked out a piece of alluminiumised steel.
Then got it into my sheet metal bender to bend it to shape.
Bit more trimming and bending........................
And some tabs for spot welds.
And it was time to use my latest tool.
This is a joggler, sheet metal tool.
One side steps the edge of sheet metal so it fits nicely behind other panels and then the end turns around to become a punch for punching the metal for the spot welds.
Stepped the edges of my panel.
And now it sits beautifully flush when placed behind another sheet.
Clamped in position.
So I could mark the end.
Took a template of the arch on the other side of the car so I could mirror it perfectly on this side.
A bit more trimming and bending.
Made another, smaller section to close off the gap at the bottom of the rear quarter, where I had cut rot away, in my other metal bender.
Coated the face of the metal that I wont be able to get to once its all welded in place, with some high heat paint.
Spot welded the small panel in place.
Followed by the main panel.
Smoothed the welds down.
And gave it a thin coat of filler.
Next I looked at the small rust hole behind the drivers side tail light.
To cut the rot out I borrowed the Dremel from work as I knew I wouldnt be able to get in with a grinder.
And cut it out.
I'm not even going to bother trying to get in there with the welder. So I will paint it all to seal and protect the metal and then fiberglass over the hole.
I had given most of the underneath a really good clean, followed by rust treating, painting and a coat of stone chip.
But I hadnt done the very back of the car, from the rear axle back, as the fuel tank was in the way.
So fuel tank off.
To reveal the area to clean and treat.
While looking at this area its clear to see the storage box that hangs down and the fuel tank actually bolts on to......................
I've been wondering lately whether a fuel tank from a V8 VDJ76 wagon would fit my LJ78, as they have a 130 litre main tank as standard.
I suspect without the tool box hanging down, which I dont think the new 76's have, I reckon it would fit.
But for now the tool box is staying.
I pushed the vehicle back so I could give it a good clean underneath.
It came up pretty good.
I also gave the tank a clean.
And all the tank related parts.
I removed the 2 pieces of curved glass from the very back side windows.
And managed to push most of the dent out.
That area then got a small coat of filler and a sand down.
I needed a flange to bolt to the turbo for my new 3" exhaust system and happened to have a piece of 12mm thick plate in the metal box.
So I marked it up ready for cutting, using the gasket as a template.
Used the drill press and the hole saws, with plenty of oil to drill the 2 main holes.
And one smaller hole.
I then cut it all out with a thin cutting disc in the grinder and cleaned it all up with a grinding disc.
All of my stainless steel tube, flanges, mandrel bends and silencer have arrived now so I will be building the exhaust system very soon.
But first I need to finish cleaning, rust treating, painting and stone chipping the underside. Then the fuel tank can go back in.
I've also made a start removing all the glass, door/window rubbers, door handles etc. ready for the respray.
The panel shop said they might be able to fit me in at the end of the month.
Oh and my new clear lights have arrived from Malaysia!
And all the genuine bits I've ordered are on their way from Dubai and Japan via Amayama.
*Edit*
@Crispin I cant delete the pics below for some reason, they keep re-appearing
