yota_lj
- Nov 17, 2016
Here my speedmoter cable KO!
Called in Toyota Italy, the want 164€+VAT for original cable, buyed at 62€ + Duty import from partsouq!
Remplacement is very very EASY. 15min and new cable is on!
I also changed all the w5w (11 for all the cluster)
Also changed my tires, adding +3cm spacer. next month I have one of bigger meeting in Europe, I'll be ready
Furthermore installe water temp gauge and added 3m Protective Sealant in my internal wheel arches.
And last week I tested excursion of my suspensions...and I suspect the they are a little bit shorter..
