Thanks mate.
Small update..............
I used a scrap piece of steel and an adjustable spanner (shifter if your an Aussie) to hold the torque convertor while I undid all the bolts holding it on.
I then removed the ring gear.
Someone has obviously been in here before as there is matchmarks.
The engine stand has turned out to be a bit of a lemon.
Now I could put up with the disgusting welds that have been thrown at it in China and the terrible paint finish they have applied over the top.
I could even put up with the fact that it wont fit between or under the engine crane properly, meaning getting the engine from the crane onto the stand is bloody difficult.
But it wont physically take the weight of the engine even though its supposedly rated at 1/2 ton.
Surely the all alloy Lexus lump doesnt weigh 500kgs?
Anyway.................
I adapted and made do, but once the engine is fitted in RJ, the engine stand is on the transfer list!
Got the engine bolted onto the stand.
But with some of the weight taken off the crane the engine stand began to list quite badly.
The pic above doesnt really show how badly it was leaning, but this one does!
So this is what I came up with so I can move it around the garage easy and work on it at a decent height.
The weight of it is all going through the blocks of wood and onto one of my heavy duty trollies.
I started to have a look at the maze of wiring.
I wanted to pull the aircon compressor off as I've removed the rest of the factory aircon from RJ as I'm planning on keeping the roof off it all the time so aircon would be pretty pointless.
Removed the ridiculously long belt and the pump.
Its left quite a gap now without the pump fitted. I want to look into moving the oil filter and fitting a bigger one so maybe it could go where the pump was.
I pulled a load more bits off the Lexus today and its getting very close to being ready to go off to the giant claw in the sky.
I pulled the fuel tank off today which because it has spent the last 24 years in the boot of the Lexus covered in carpet, is in pristine condition!
Not sure if I can use all of it, just the fuel pump, or non of it yet. But figured it was worth saving for now.
I've been building up a folder of information I've collected online.
I've got all 87 pages of the excellent "How To Wire Up A 1UZ-FE" by Nigel Wade, that Ryan kindly emailed me.
And I've just added the excellent 15 page document by Phil Bradshaw.
I've got a few more articles and documents to print out which I think will help with the conversion and as I get 4-5 hours of down time every day at work, I will take the folder in with me and have a good read.
I did a tiny job on RJ today that has been bugging me since I got the car.
The previous previous previous owner who resprayed the car in Zion blue with airbrushed flames also decided to remove all the badges and weld the mounting holes up.
So RJ was missing the classic LandCruiser badges off the front guards.
I had got spare badges.
Just needed to cut the tabs off.
Applied some 3M double sided foam automotive tape.
And stuck them on back in their rightful spot, just like the 40 series before it and in fact all the LandCruiers before that right back to the 20 series!
