I can't see the 2wd versions of the 80 series having a center diff as such. The add mentions 2 OE difflocks, not 3. It'll more likely be just a bevel gear drive to the front prop, as in old series land rovers, Suzuki SJ's etc so you can't use it on road without transmission wind up. You could leave the hubs locked permanently without engaging 2wd but this would mean the front wheels would be turning the front diff/propshaft so would negate any wear and economy benefits of the 2wd setup.
The 80 without full time 4wd came as standard in most markets with just a driveflange on the front hubs, and without a diff in the transfer box. That way you could not disconnect the front prop, and just move the little lever to engage the fronts. That would give binding on firm ground, but very OK on gravel, snow, etc.
Some models/markets came with the manually lockable front hubs, so that you could disengage the front prop and diff altogether. This was the standard for many company-fleets of cruisers.
There is also a version of auto locking front hubs, where the hubs would engage when the prop started turning the shafts, and disengage if the hubs where driving the prop. Not very common tho, but it was available as an extra.
Depending on the market, the 80's with part time 4wd would have front and rear locker, or rear only.
The fleet of 80s in the UN Middle East in the 90s had manually lock front hubs and F/R diff locks, except for the newer ones which had flanges up front (a result of learning the hard way). The manual front hubs would normally stay locked all the time, but of course when you needed it the most, some wise-guy had turned the dials to "unlock".
