To update this thread i have moved pressure and temperature sensor up onto the intercooler the details of which can be found here
http://www.landcruiserclub.net/foru...ie-i-need-some-wiring?highlight=broken+collie , and in doing so the end of this saga is in sight . It really should have been obvious from the start that the sensors are the key to the electronic pump conundrum .
With the sensors in the right place taking the correct readings allowing the ECU to adjust fuelling accordingly all of a sudden the K&N high flow air filter + 3" exhaust + turbo actuator washer mod + retrofit intercooler all finally feel as though they are working together as one .
Today i finally got around to removing the throttle body butterfly and was happy to learn the retaining screws can be screwed out because the thought of drilling right through them made me cringe thinking about what rubbish might end up in the manifold . I had some limited success getting one out using a precision screwdriver which let me know they would screw out , so i popped down to screwfix and got myself a screw extractor set which pulled them no bother at all .
Whilst doing this i noticed the part i had fabricated to allow me to fit the intercooler wasn't very tidy
So spent and hour polishing it up which is laughable considering the flexi part of my intake pipe has about 5 layers of gaffa tape holding it together (note to self remember to buy a new polishing wheel and intake pipe
Put it all back together and took it for a test run . Result
the truck finally feels like it came off the assembly line as is and it hasn't been molested at all . Its time to start searching for a rolling road me thinks .
