The LR swivels have oil in them, not grease. The one shot grease is and additive designed to thicken the oil to stop a slow leak.
Have to disagree with some of that quote Frank. The older Land Rovers did indeed have oil in them, but Land Rover introduced the 'one shot' grease supplied in a measured 'toothpaste tube'. After a rebuild you just used the later grease, only found out about it when talking to a guy with a Santander (Spanish Land Rover), he said they (LR owners) had used it for years in Spain and was quite shocked that I was not using it.
It is still quite runny, akin to sloppy black CV grease but seemed to work ok in road and competition use.
Re using it in the LC I cannot see there being an issue apart from cost, IIRC it used to be one tube per side? For the LC it would probably be three aside?
I would guess it is the normal moly as per typical CV grease, unless there is an additive the LC needs?
regards
Dave
regards
Dave
