Hello Guys!
1. Thanks for some of the good feedbacks left on here
I do apologize for my english not being to everyones standard, it is only my 4.language so please do bear with me.
It has been a severly busy week & I am sorry for not having got bak on here earlier!
I ordered the replacement engine last friday & they dismanteled & shipped it to me. I was woken up by the truck driver Thrusday morning who had dropped a wrapped pallet on my door step. I had asked the breaker to include the electric harness as I did the bad mistake (perhaps...) of not pulling bakc the wires from the ECU prior to dismanteling.... So the replacemnt engine came with all goodies. I had to resolder some busted connectors I salvaged off the excisting loom & modified the new loom to accept the tune box.
Dropped her on late Thursday night with the Madame as a helper.
Friday was not utterly fruitfull as I among others had to buy a new engine hoist. The old one was unsatisfactory. So I completed her yesterday. Filled all the fluids, barey starred at the ingition barrel & she sprung straight back to life
Purred like a kitten
No leaks, no fluids escaping, no bad at all.
Something must have gone right here
Not to another Q; What is a good way & a good tool to use to tighten the bolt holdig the flex plate to the converter? I skinned most of my hand dismantling. I have tried with short 14mm socket, 3/8 UJ & Extentions to clear the cross member. I do seem to slip ( NO, not f*ck any bolts yet
) before I get the tention I want on them.
Any advice would be greatly appreciated.
I will test drive here later today, give her a good spin. Change oil & filter again.
Cooling side was flushed good. The rad seems to be rather new. I hope that should sort the potential cooling issue.
Having a look at the old block, I did not see any scaling, sludge or smilar. So comparing with what I have seen on many other engines, this does infact look very clean!
Hmm
What I did come across however, was a bottle of som very thin 5W-40 Synth Oil in the truck. Not the best brand I am afraid. May this with some of the other now known aspects have lead to the premature failure
I still have to whip off the oil pan. I will do so & inspect the bearings.
Believe me, I do too what to get my head around what has happened here.
The remains of the engine will be stored in my buddies shed. I sorted him a narrow body LC 95 last summer. We are looking at tuning his engine & fitting a top-mounted Navara IC. Now I have an inlet duct to bucther
Will possibly redo the complete ram. Need to do som flow-testing first, but that OT here
