Toolangi & Black Range State Forests 4WD Trip.
I only work Monday to Thursday, so on Friday I loaded up The 78 and headed off for Toolangi just after lunch.
Toolangi, which is the closest edge of the High Country to where we live is a 40 min drive away and from there its possible to drive for weeks into the High Country which covers an area of thousands of square miles of forests, mountains and rivers!
I managed to squeeze the RV5 tent inside the car as I still havent fitted a roof rack.
I soon reached Toolangi and drove in from the Narberthong side.
Passed an area of recently harvested trees.
Locked the hubs in on The 78.
And continued on my way into the forest.
My friends Jiri and Aneta, who would be joining me later that evening had marked on the map 3 possible camp sites (highlited in orange).
The first one proved to be nothing more than a small patch of dirt at the side of the road so I continued driving onto camp site number 2.
And this one proved to be perfect!
The tent was soon setup, after all it is the original 30 second tent!
It was next to a pretty little river.
And even Lexi approved.
The fire was soon lit and cold beers out of the Engel.
I cooked dinner over the fire and as I always cook on the fire I dont even bother carrying my gas stove and gas bottle anymore, its much nicer and more traditional to cook over a fire than using a gas or fuel stove!
Potatoes and carrots in the pot boiling away.
And marinaded chicken skewers!
I sat enjoying the fire, beer and music while being mesmerised by the millions of stars I could see in the clear nights sky and a few hours later I was joined by Jiri and Aneta.
We sat around drinking late into the night.
The next morning I was up bright and early and the fire was soon going again ready to cook breakfast.
Sausage, egg, melted cheese, BBQ sauce on a toasted brioche bun, washed down with a litre of tea.
Jiri and Aneta got up and ate their breakfast and then we packed the camp up and hit the tracks.
The day would end up being known as "Fallen Tree Day" and it all began on the next track.
I figured we could squeeze under the big tree if we cut the smaller ones out of the way, so out came the chainsaw.
Just enough room.
After a few hundred meters we came across more trees we needed to clear.
And then more trees.
At this point we decided to give up on this track and turn around as the track looked very flat on the map and didnt look all that interesting and we didnt want to waste all day cutting trees off a boring track.
We drove a few more tracks and all was going well.
Then we came across a huge tree blocking the track!
So we got the tools out and got to work.
First I cut up from underneath about half way through and then did 2 cuts from the top to take a wedge out, so that the top cut wouldnt close up and jam the saw.
Jiri cleaned the top cut out with the axe.
And then did some more chainsawing.
As the tree was so big and the saw so small, we had to cut from both sides.
Birdseye view.
We then cut the other end of the tree and attached a snatch strap to the tree to try and pull it out of the way.
At this point we had cut virtually all the way through at both ends, but now the almost loose section was jammed against the other sections of tree.
We attached the other end of the snatch strap to the front of the Troopy and used a bridle to spread the load over both chassis rails.
And Jiri gave it a good few pulls, as can be seen in the video below.
As can be seen it creaked and cracked and moved a bit but it didnt come crashing down.
So we re-positioned the strap and were much more successful this time!
We rolled it off the side of the track and continued on our way.
A few tracks later we came across another fallen tree blocking the track.
As one end was already broken we figured we might be able to drag it out of the way, so we hooked the Troopy up and Jiri gave it a few pulls.
